Case with shell conduction fails in parallel run for certain number of partitions. Error message is: shell conduction zones, Checking contact points… Migrating 66 cell(s) across compute nodes… ============================================================================== Node 10: Process 123634: Received signal SIGSEGV. … *** Error in `/ott/apps/software/ANSYS193/ansys_inc/v193/fluent/fluent19.3.0/lnamd64/3ddp_node/fluent_mpi.19.3.0′: free(): corrupted unsorted chunks: 0x000000000718f400 *** *** Error in `/ott/apps/software/ANSYS193/ansys_inc/v193/fluent/fluent19.3.0/lnamd64/3ddp_node/fluent_mpi.19.3.0′: free(): invalid pointer: 0x00000000079d47e0 *** *** Error in `/ott/apps/software/ANSYS193/ansys_inc/v193/fluent/fluent19.3.0/lnamd64/3ddp_node/fluent_mpi.19.3.0′: free(): invalid pointer: 0x00000000079d47c0 *** ======= Backtrace: ========= …
January 25, 2023 at 7:16 am
FAQParticipantThis error message can occur if the shell encapsulation method is not activated. This method is activated by default in release 2019 R1, but might be deactivated when an older cas-file is opened. To fix this issue enter the following TUI-command. /define/models/shell-conduction/enhanced-encapsulation? yes Also see the documentation here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/flu_ug/flu_ug_sec_partition_trouble.html
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- Thermal Analysis of a Radiator Using Ansys Fluent
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- Simulating Battery Pack Cooling System Using Ansys Fluent
