Can’t launch Workbench or AIM with error: Could not load file or assembly ‘IronPython, Version=2.7.5.0,….
August 25, 2023 at 12:16 pm
Solution
ParticipantPlease refer to the attachments to access the Solution
1. 2049451.pdf
- Q: How do I set the license server from my client machine?
