Tagged: 19, CAD Interface, fluid-dynamics, General, icem-cfd
March 17, 2023 at 8:58 am
FAQParticipantDelete in your home directory the ICEM CFD cache files (.aienv_xx, .aienv_options). set tickmark at : Settings: Tools -> Mechanical Preprocessing If this fails create a shortcut of the ICEMCFD start icon to your desctop and open the Properties field. Add in the Target field behind the entry icemcfd.bat the option -fsi e.g.: “C:Program FilesANSYS Incv190icemcfdwin64_amdbinicemcfd.bat” -fsi
- Skewness in ANSYS Meshing
