Can you scale your mesh controls by a factor, when using the Watertight Meshing Workflow in FLUENT Meshing?
Tagged: 2019 R2, FLUENT Meshing/Tgrid, fluid-dynamics, meshing, Watertight, Workflows
April 13, 2023 at 7:32 am
SolutionParticipantThis is possible but will need some Customer Journal lines to be added to the workflow. Find attached a zip file containing an example case where you can set a mesh scaling factor as part of the workflow. This involves inserting a Custom Journal file into the workflow. This contains a few lines of TUI commands. If you open FLUENT in meshing mode. Open the Workflow template, it should all be set up. You will be able to see the additional Run Custom Journal entry and the lines this includes. This is all you will need to add to your set up.
1. 2059818.zip
- Skewness in ANSYS Meshing
