Tagged: 19.1, contact, dm, General, mechanical, Spot weld, structural-and-thermal, structural-mechanics, Virtual Topology, welds
March 17, 2023 at 1:12 pm
SolutionParticipantPlease download attachment to access solution
1. 2054744.zip
2. 2054744_spot_weld.pdf
