January 25, 2023 at 7:34 am
FAQParticipantWhen post-processing stresses on surface bodies, several options are available. – For stresses derived from the stress tensor (components of the stress tensor, Von Mises stress, principal stress, intensity), you can choose the position where you want to look at the stresses. By default, the “position” option is set to “top/bottom” : the stress plot varies linearly through the thickness from the top face to the bottom face. When setting the “position” option either to top, bottom or middle, you are specifically asking for the results obtained on the top face, bottom face, or middle surface. – For stresses specific to shell elements (bending and membrane stress), the result is obtained through a through-thickness integration, so there is no “position” option available.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
