June 6, 2022 at 8:33 am
FAQParticipantSo far, Chemkin Pro is a standalone program, or launches under Reaction Workbench, which accesses a number of chemistry tools, including Chemkin Pro. Chemkin Pro models mostly batch processes. It is not integrated with ANSYS Workbench because there are currently no inputs there that it requires for modelling – such as mesh and geometry. Note that, unlike Chemkin, Forte is integrated, because it can accept an ANSYS mesh file as geometry input for the 3D IC engine simulations it performs.
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
