June 6, 2022 at 9:58 am
FAQParticipantPLNLAB use to be called STLOC. STLOC – Starting location in table for entering data. STLOC must be greater than or equal to 9. Locations 1 through 8 are reserved for internal parameters. STLOC may also be set to DELETE. If STLOC = DELETE, then all loads defined for the specified section will be deleted and the remaining fields will be ignored. It would appear that we still reserve the first 8 values “for internal parameters”. The spacing (9,14,22…) is strategic to allow room for the other fields when multiple preloads are defined.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
