Can you clarify the units of reaction rates in the porous zone when determined via define_vr_rate? It is kmol/m^3 s according to the define_vr_rate documentation. In a porous zone, is the m^3 referring to the total volume, the volume of voids, or the volume of solids?
Tagged: 19, fluent, fluid-dynamics, Scripting/Journaling/UDF, Species/Reactions
January 25, 2023 at 7:17 amFAQParticipant
It is kmol/sec/m^3. where the m3 express the gas volume only. Fluent take this value for the UDF and multiply it by the porosity which is (gas volume/total) volume so it ends up in the transport eqn as kmol/sec/m3(total volume). In other words, if you are using it in UDF then in your UDF you need to supply it as per gas volume only.
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- LES Simulation of Turbulent Flames Using ANSYS Fluent
- How can volume fraction be plotted in a species transport simulation?
