Can we calculate the view factors for S2S radiation model between 2 surfaces without mesh between them..?
April 5, 2023 at 2:32 pm
FAQ
ParticipantNo, for view factor calculations mesh ( fluid zone ) needs to be present between the participating surfaces
- Defining heat transfer coefficient (HTC)
- Thermal Analysis of a Radiator Using Ansys Fluent
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How to use Thin Walls with Thermal boundary conditions?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- What is the difference between internal and external emissivity?
