Tagged: 19.2, fluid-dynamics, General, system-coupling
June 5, 2023 at 7:06 am
FAQParticipantIn 2019R1 there is BETA capability which allows this to be done using the command line workflow. Below is an example set of commands to accomplish this: DatamodelRoot().ActivateHidden.BetaFeatures = True DatamodelRoot().CouplingParticipant[‘FLUENT-1’].UpdateControl.Option = ‘StepInterval’ DatamodelRoot().CouplingParticipant[‘FLUENT-1’].UpdateControl.UpdateFrequency = 5 DatamodelRoot().CouplingParticipant[‘FLUENT-1’].UpdateControl.PrintState()
- Skewness in ANSYS Meshing
