Tagged: 18, cfx, fluid-dynamics, Heat Transfer and Radiation, Other, trace file
June 5, 2023 at 7:05 am
FAQParticipantThere is currently no way to re-use ray trace files in CFX. By default, the ray trace file is created in the run directory and deleted after the run completes. For a parallel run, a separate ray trace file will be written for each partition. When using the Monte Carlo or Discrete Transfer radiation models, the output files discussed in section 3.2.16. CFX Radiation File can be obtained by setting the Diagnostic Output Level to 1 or 2 under Solver Control > Advanced Options > Thermal Radiation Control (see 10.8.5.2. Diagnostic Output Level in the CFX Modeling Guide).
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
