Tagged: 2020 R1, fluid-dynamics, mesh-quality, meshing
March 17, 2023 at 1:10 pm
SolutionParticipantPlease refer to attachment to access the solution. This shows how to check bad elements. Please check solution # 2062570 for how to improve these elements. Keywords: quality, bad, skewness
1. Check_bad_cells.mp4
- Skewness in ANSYS Meshing
