Can not open WB file. Getting error as following. The design point file to be loaded does not exist:D:Userstestcase_filesdp0designPoint.wbdp”
Tagged: 19.2, fluid-dynamics, General, workbench, workbench platform
April 5, 2023 at 2:31 pm
FAQParticipantPlease copy corresponding files to destination folder i.e. dp0 folder. This will allow you to open WB file.
- Skewness in ANSYS Meshing
