Can mesh adaption following a moving interface be provided with different refinement levels in the x, y, or z direction?
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: adaption, refinement, interface
1. 2049294.pdf
- Skewness in ANSYS Meshing
