General
General
Can I use the PRESTO! pressure interpolation method in conjunction with NITA?
    • SolutionSolution
      Participant
      The PRESTO! pressure interpolation scheme, when used with the non-iterative time-advancement solver, is less stable than in the case of the iterative time-advancement solver. As a consequence, smaller time steps may be required. Therefore, if you are using the NITA, please use smaller time step size when facing stability issues or select a pressure interpolation method other than PRESTO! For further details, please refer to the documentation in the ANSYS Fluent Users Guide  Using the Solver  Pressure-Based Solver Settings  Setting Solution Controls for the Non-Iterative Solver
      1. 2042102.pdf
