Tagged: 18.1, fluent, fluent-post-processing, fluid-dynamics, post-processing
January 25, 2023 at 7:16 am
FAQParticipantData Sampling in steady-state: 1) In general, not advisable as may not represent a physical solution 2) Some more or less plausible argument can be made about pseudo-transient in situations when the solution settles into a quasi-oscillatory state indicated ongoing unsteadiness. In this case one can argue that an average of the pseudo-transient solution could be a representative of its steady-state. In this case, this can be implemented via a straightforward UDF.
- Skewness in ANSYS Meshing
