Can I use A Chemkin mechanism to read in my Eddy Dissipation reactions rather than entering them by hand? This seems not to be supported. I can read in the mechanism, but when I switch to Eddy Dissipation, the A and B coefficients are greyed out and zeroed.
Tagged: 19.2, Eddy Dissipation, fluent, fluid-dynamics, General, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantThis behavior is due a defect in the Fluent GUI. (Will be fixed at V 19.3). Once you import the Chemkin mechanism, edit the Mixture material and visit the Reactions panel once (without changing anything) and click the OK button. After this, you can switch to Eddy-dissipation or Finite-Rate/Eddy-Dissipation model as usual
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
