March 17, 2023 at 8:58 am
FAQParticipantChemkin needs GUI. Forte can be run without GUI. There is a script to run Forte on remote cluster. However you have to setup the file in GUI and submit it to the cluster. So here also you will need GUI.
- Skewness in ANSYS Meshing
