Tagged: 19.2, fluent, fluid-dynamics, Heat Transfer and Radiation, radiation, solar-load
January 25, 2023 at 7:16 am
FAQParticipant1) Semi-transparent wall option under the radiation tab in wall boundary condition panel IS NOT available with S2S radiation, as S2S on calculates the radiative heat transfer based on view factors, and does not consider the medium participation 2) however, when the Solar Load model is switched ON with S2S radiation model, now an external or internal wall can be made semi-transparent to account for absorption, transmission & reflection of the radiant solar load at the surface
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
