Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantANSYS Help does have some information about Memory and Disk Usage Estimates: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v190/ans_per/perlineqsolv.html You can also estimate the required space by doing some small tests on your end. For example, if your model has 100 steps, you may run 5 steps first and check result files. The space required for 100 steps can be approximated as “the space for 5 steps x 100/20”.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
