January 25, 2023 at 7:16 am
FAQParticipantExternal walls can only gain direct solar heat flux if they are semi-transparent (with an absorptivity > 0). Opaque walls do not gain any direct solar heat flux. For this purpose, parts of the surrounding have to be modeled, so that solar heat flux can enter through e. g. a pressure inlet.
- Defining heat transfer coefficient (HTC)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to use Thin Walls with Thermal boundary conditions?
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- What is the difference between internal and external emissivity?
