Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantBoth the Boundary Layer Channel flow model and the Stagnation Flow/Rotating Disc CVD model will handle surface reactions with diffusion. The Stagnation Flow/Rotating Disc CVD model handles flows parallel to a reacting surface and the second model will handle impingement flows on a reacting surface. Both models can model diffusion at the mixture-averaged (Fickian) level or at the full multicomponent level.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
