Can ANSYS use higher order elements for the best mesh in mesh independent modeling, such as modeling the reinforcements of tires, concrete, etc?
April 5, 2023 at 2:33 pm
FAQParticipantYes, at R19, high order elements are now permitted in the base mesh.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
