Can ANSYS be used to simulate the fluid structure interaction i.e. sloshing of two partially filled containers of fluid impacting?
Tagged: 17, General, structural-mechanics, system-coupling
August 25, 2023 at 12:16 pm
SolutionParticipantYes. Please see the attached document and video.
1. 2049172%20FSI%20of%20two%20containers%20partially%20filled%20with%20fluid.pdf
