March 17, 2023 at 8:59 am
FAQParticipantA solid zone cannot be smoothed with the Diffusion and Linearly Elastic Solid Method. Only the Spring smoothing method can be used. If the volume of a solid changes, you must expect mass and energy imbalances Keywords: dynamic mesh; moving deforming mesh; MDM
- Skewness in ANSYS Meshing
