Can a single file be split into separate domain files (Inlet, Passage) in Turbo Grid and exported to simulation.
Tagged: 19, CFX-TurboGrid, fluid-dynamics, General, turbo, turbogrid
May 15, 2023 at 8:32 amSolutionParticipant
Please refer attachment to access the solution
1. 2054588TG%20Single_%20CFX%20Multiple%20Files.pdf
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
