Tagged: 18.2, cfx, fluid-dynamics, rotating-machinery, TBR, transient-blade-row, turbo
June 5, 2023 at 7:05 am
FAQParticipantGenerally, mass flow boundary conditions should be avoided when using the FT-TBR method as it makes the solution unstable. This is because the periodics have defined mass flows due to phase shifting. Additionally, most transient cases will not have a constant mass flow rate and imposing one would be non-physical. The use of static pressure for outlet boundary conditions is preferred over mass flow outlets. Similarly, using a total pressure inlet boundary condition is preferred over a mass flow inlet.
- Skewness in ANSYS Meshing
