Bushing joints using constant stiffness, it works fine, but when using tabular stiffness, why it does not work as expected?
January 25, 2023 at 7:34 am
FAQParticipantThe tabular stiffness is for the relative MPC184 displacement, and sometimes there can be issues due to the sign convention and the fact that many only put in a portion of the load/deflection (moment/rotation) curves and do not put the negative portion. So, if there is no data, ANSYS will interpret as zero stiffness for the negative relative displacement. It is required to define load/deflection (moment/rotation) curves for both positive and negative deflection.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
