Both ANSYS and FLEXlm installations lock up, specifically during configuration according to the status window. No error, just a message that it’s configuring the system to install ANSYS and/or FLEXlm during the installation process. What causes this?
March 17, 2023 at 9:01 am
FAQParticipantIn this case, a program called Retrospect was running. After shutting this down, the installation continued successfully. There are other processes that can also cause this to occur. You can try using Task Manager to kill suspect processes. Once the offending process has ended, the installation will continue.
