Borrowed license stuck ‘Display License Status’ was showing license was borrowed. But the command “lmutil lmborrow -status” was showing that no licenses are borrowed.
January 25, 2023 at 7:28 am
FAQ
Participant1. Stop ANSYS License Manager (Either in Services or the License Management center) 2. Create an options file (“C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.opt”) 3. add EXCLUDEALL for the user ids showing the license borrowed in license status. – This step will prevent the license usage by those user ids. 4. Start ANSYS License Manager 5. All license borrow entries are gone 6. Wait for 3 minutes. 7. Stop the License Manager again. 8. Remove the option file. 9. Start the ANSYS License Manager again.
