April 8, 2025 at 4:49 am
Watch & LearnParticipantBi-directional CAD connectivity in Ansys Discovery allows for seamless integration and interaction between CAD systems and Ansys Discovery. This feature enables you to change parameters in the CAD system directly from Discovery, and those changes are reflected back in the CAD system. For example, if you are using Inventor or NX, any parameter changes made in Discovery will be updated in the CAD system as well.
This connectivity ensures that geometry, name selections, parameters, and other metadata are transferred directly to Discovery, allowing for operations like history tracking and parameter tracking. This means you can modify geometry in Discovery and have those modifications reflected back in the CAD system, supporting a bi-directional connection.
- Surface to solid creation in SpaceClaim
- Ansys Discovery – Detect Tool
- Ansys Discovery – Working with Components
- FAQ – Share Topology is now available in Discovery 2021 R2
- Changing the visibility of bodies from transparent to opaque or vice-versa
- Discovery Quick Tip- How to update your geometry from a source CAD File
- Selecting all inner faces of a body
- Split Face in SpaceClaim
- Quick Tips for Volume extraction in SpaceClaim
- Stitch Faces & Split Edges Tools in SpaceClaim
