June 6, 2022 at 9:58 am
FAQParticipantTemperatures may be input as element body loads at the corners of the outside faces of the element and at the corners of the interfaces between layers. For the one layer shell element, 8 temperatures are required as input T1 through T8.
BFE commands specifies temperatures T1 through T4 when STLOC=1. To specify temperature T5 through T8 an extra BFE command should be used with STLOC=5. If STLOC = 5, data input in the VAL1 field applies to the fifth element item and so on.
For example,
BFE,ALL,TEMP,1,%TEMP_TABLE% ! Specifies temperature T1 through T4
and
BFE,ALL,TEMP,5,%TEMP_TABLE%! Specifies temperature T5 through T8
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
