Tagged: ansys-fluent, external-aerodynamics, meshing, y-plus
June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video describes the best practices to generate a mesh and select the appropriate turbulence model for external aerodynamics problems. You will learn how to calculate the Y+ value and refine the mesh near the wall. For questions or to learn more visit http://www.ansys.com/studentcommunity
- Skewness in ANSYS Meshing
