Tagged: ansys-mechanical, BAJA SAE, chassis, fsae, Rear Impact, Roll over, roll-cage, Student Team, Torsional Test
June 6, 2022 at 9:30 am
Watch & Learn
ParticipantThis video shows how to carry out roll over, rear impact and a torsional test of the chassis in ANSYS Mechanical. You will learn how to determine the resulting stress and deformation due to various impacts on the chassis. For questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
