Tagged: ansys-mechanical, BAJA SAE, chassis, Front & Side Impact, fsae, roll-cage, Student Team
June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video shows how to generate a mesh, and apply loads and boundary conditions in ANSYS Mechanical. It shows how find out resulting stress and deformation due to front and side impact on the chassis. For questions and support, join the ANSYS Student Community: https://studentcommunity.ansys.com/
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to change begin node and element number for meshing in Workbench Mechanical?
- What is the difference between shell 63 and shell 181?
