June 5, 2023 at 7:05 am
FAQ
ParticipantFlexNet, the license management software used in ANSYS, requires Linux Standard Base (LSB) 3.0 package, which may require the additional installation of some additional packages. Please ensure that the appropriate packages are installed.
