As well as for traditional post-processing tasks, CFD-Post is very useful for viewing meshes. Certain file types can be loaded directly into CFD-Post (.def, .gtm, .cgns), but what about the others?
June 5, 2023 at 7:05 am
FAQParticipantOf course CFX-Pre can be used to import the mesh and generate a .def file, but this is overkill, especially if the process is to be repeated many times. If the user is not averse to a little command line work, then cfx5gtmconv can be be a great time-saver. The cfx5gtmconv utility allows a wide variety of mesh formats to be converted to a format viewable in CFX-Post. The following command would create a minimal .def file from an ICEM mesh file, where project1.cfx5 is the file output from ICEM and test1.def if the file to be created: cfx5gtmconv -icem project1.cfx5 test1.def The first argument denotes the input file type and can be omitted in cases where the file extension is recognised by cfx5gtmconv. For example, a CFX-4 mesh could be converted as follows: cfx5gtmconv m01.geo test1.def A list of compatible file types and additional options accepted by cfx5gtmconv can be obtained by running: cfx5gtmconv -help
- Skewness in ANSYS Meshing
