As of Java 11, the Oracle JDK will require a commercial license What are your applications plans for dealing with this licensing change and will your application provide support for OpenJDK?
March 17, 2023 at 9:01 am
FAQParticipantANSYS regularly updates to the most current public release of Java SE Development Kit 8 for each ANSYS product release to address security vulnerabilities and other defects. ANSYS plans to upgrade to OpenJDK which is an open source implementation of the Java SE platform.
