Are there examples to understand procedure to Frictional heating prediction simulation between rotating or sliding bodies using coupled Thermal-Structural coupled field elements ?
March 17, 2023 at 1:11 pm
SolutionParticipantRefer two examples in attachment.
3. 2058246.zip
