Tagged: mechanical, mechanical preload, structural-mechanics
June 6, 2022 at 9:30 am
Watch & LearnParticipantIn this video, we will see how to apply bolt pretension to a beam connection. We need to first create joints for each of the line bodies that represents the beam connections.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
