ANSYSLI exited or could not read server port ansyscl..####.####. Please refer C:WindowsTEMP.ansysansyscl..####.####.log for more information.
- .####.####. Please refer C:WindowsTEMP.ansysansyscl.
.####.####.log for more information." target="_blank" rel="nofollow" title="LinkedIn"> - .####.####. Please refer C:WindowsTEMP.ansysansyscl.
.####.####.log for more information." target="_blank" rel="nofollow" title="whatsapp"> - .####.####. Please refer C:WindowsTEMP.ansysansyscl.
.####.####.log for more information." target="_blank" rel="nofollow" title="reddit"> - .####.####. Please refer C:WindowsTEMP.ansysansyscl.
.####.####.log for more information." target="_blank" rel="nofollow" title="facebook">
Tagged: 2021 R2, Ansoft RSM, ANSYS CL, HFSS - SYS, Installation/Licensing/Systems, Remote Solve, rsm, system
March 17, 2023 at 9:00 am
FAQParticipantMigrate to the AnsysEM2022R1 or later release. The COM engines now connect to the ansyscl process running on the ansysedt host. Affects AEDT 2019 R2 through 2021R2 Keywords: ANSYS CL, Ansoft RSM, SYSTEM
