June 6, 2022 at 8:45 am
Watch & LearnParticipantThis 2-part series of ANSYS How To videos demonstrates the setup and solution of a two-way transient coupled analysis of an oscillating plate, using ANSYS Mechanical, ANSYS Fluent, and System Coupling. Part 1 shows the setup of the three systems in ANSYS Workbench’s Project Schematic, and reviews the settings specific to a coupled analysis in ANSYS Mechanical and ANSYS Fluent. System Coupling in ANSYS Workbench provides tight integration of ANSYS Fluent and ANSYS Mechanical to allow the most complex Fluid-Structure Interaction phenomena to be simulated in a single environment. Part 1 of 2. For more information, please visit ansys.com.
- Skewness in ANSYS Meshing
