Tagged: ansys-mechanical, ansys-student, fatigue, Hub
June 6, 2022 at 9:30 am
Watch & LearnParticipantThis video demonstrates how to perform a fatigue analysis of a hub for a Fomula SAE car.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
