ANSYS SpaceClaim: With the 2017.0 version, I cannot add vertices with the doubleclick in the skin surface tool ?
Tagged: 18, ANSYS SpaceClaim DirectModeler, Edit Group, fluid-dynamics, geometry
June 5, 2023 at 7:05 am
FAQParticipantThat is a known issue. You need to first click once to make the yellow dot, then wait a second, and double click the yellow dot to create blue dot for adding vertex. It’s a regression that has already been addressed in the 2017.1 release.
- Skewness in ANSYS Meshing
