Tagged: 18, ANSYS SpaceClaim DirectModeler, Edit Group, fluid-dynamics, geometry
June 5, 2023 at 7:05 am
FAQParticipant“The two main reasons skin surface might fail is: 1) The mesh has errors and the STL addin is needed to heal the STL or shrinkwrap it. 2) If you are using planes to create a boundary for the skin surface, they might be too far away, or the geometry between them is too complex…try moving the planes, or using more planes”
- Skewness in ANSYS Meshing
