ANSYS SpaceClaim: When I open a large assembly, I get some time lag while performing actions like pull . Is there any way to suppress the other components when I work on a particular component? I tried deleting the other components and working on only the single component in a large assembly but I still get some lag.
Tagged: 18, ANSYS SpaceClaim DirectModeler, fluid-dynamics, General, geometry
June 5, 2023 at 7:05 am
FAQParticipantThe easiest thing to do is open the individual component you’re working on by right clicking the item in the structure tree and selecting Open Component. You could also hide the other components temporarily by selecting the desired item, then using right click > Hide Others in the main window. The first method is preferable, since you can close the main assembly.
- Skewness in ANSYS Meshing
