ANSYS SpaceClaim: When I do pull or move along a curve, can I define the operation distance from the starting point?
June 5, 2023 at 7:05 am
FAQ
ParticipantIf you press the Space bar on your keyboard while Pulling, you’ll be presented with a field to enter a distance. For the Move tool, start moving the object along the curve a small amount, then press the Space bar to get the field.
- Skewness in ANSYS Meshing
