ANSYS SpaceClaim: When first entering for example a rectangle, I can Switch the two input fields using the TAB Key. But when I go to edit a previously created Rectangle, I select the width and the length editing box becomes active instead. Then when I hit the TAB key to switch the editing box nothing happens. Why?
June 5, 2023 at 7:05 am
FAQParticipantWhen you’re selecting that line you’re telling SpaceClaim which line you want moved. That’s why you get the opposite dimension you’re expecting. You can’t tab between them because that would mean tabbing between selection and we couldn’t know which of the perpendicular lines you’re expecting to change.
- Skewness in ANSYS Meshing
