June 5, 2023 at 7:05 am
FAQParticipantBy default, the LMGRD.exe process uses port 27581. The SPACECLM.exe daemon uses a random open port. If you go into C:SpaceClaim Flex Server on the server machine, you will find a file called “lic.log”. In there you will find the 2 ports in use by the processes I mentioned above. If customers have an existing Flex server, they can use that to host the SpaceClaim license. Just copy SPACECLM.exe and sc.lic into the same folder as their other server, and set the process up using LMTOOLS.exe.
